I have installed a lot of laminate in 1st floor rooms, with concrete subfloors. No issues there. Now I'm installing in a second floor bedroom in a townhouse. Before I rip up carpet Im checking to see if there are any special considerations to consider for 2nd floor installations.
I know this question is a little broad so I'm up for edits to make more specific.
  • Well, the second floor probably won't have concrete subfloors. Outside of that, I'm not sure why you think there might be special considerations.
    – keshlam
    Jan 1, 2015 at 6:28
  • Thank you! I was thinking about the issues with noise ( is a thicker sound barrier required) should a moisture block still be used? But idk if it's that similar then I guess I'm all good?
    – rhill45
    Jan 1, 2015 at 6:32
  • Moisture block isn't needed since moisture shouldn't be present. I'm not sure why a sound barrier would be needed in either case.
    – keshlam
    Jan 1, 2015 at 6:35
Utilize a high rated sound barrier to cancel noise.
  • Could I use 2 layers?
    – rhill45
    Jan 4, 2015 at 5:39
