I'm looking for a fast and precise way to cut precise pieces of ceramic tile. Any recommendations on tools with pros and cons would be appreciated.
Thanks!
Sign up to join this communityI'm looking for a fast and precise way to cut precise pieces of ceramic tile. Any recommendations on tools with pros and cons would be appreciated.
Thanks!
You need a diamond tile saw, where you put the tile on a platform and slide it past the water-cooled blade. They are fast, precise and good for the hardest porcelain tiles. Expect to pay $300 and up. Straight cuts are the easiest. To cut out a square corner, make the two cuts with the tile upside down. The back of the tile will be a mess, but the business-side will be tidy.
If you want the cut edges to be velvety smooth to walk on or rub skin against, use some damp 400 grit wet/dry held at a 45degree angle to the sharp edge.
Score-and-snap tools are fast for cut edges that will be hidden by a baseboard.
Cheaper saws where you push the tile through (like a table saw) are OK, but not as fast and versatile as the sliding-table models.
For round holes for shower heads etc, use a diamond hole saw. If the tile is porcelain, submerge it in water on a bit of plywood while making the cut.
For rectangular holes for electrical boxes, use a diamond hole saw for the four corners, then use the tile saw from the back, like a mitre saw.
The wet diamond blade is pretty amazing - it will cut through tiles but is fairly safe on fingers. You can hand-hold tiles for tricky trimming without too much danger. (at least so far!)
