I am in the process of buying a house. The home inspector noted problems with the deck, most significantly "leaning posts."
- What would be required to get those 4x4 supports adequately secured to the deck surface?
- Does the fact that some of the precast foundations are tilted (that one in the back is just horrifying) mean that I'll need to have those reseated?
- Is any of this work feasible without disassembling the entire thing -- is it a better idea to look into a complete rebuild?
This isn't a tall deck (~3-4 feet off the ground at highest point), and the surface is approximately 15x15 feet.
