i have a train xl80 furnace. When it calls for heat the draft inducer fan turns on and then the burner fires up for a short time then shuts off then it starts all over again.I am thinking its the flame sensor. please help.
    Does it have any indicators to show fault codes? Sure sounds like a dieing flame sensor, but it could be a loose connection or a bad board as well. – Tester101 Dec 22 '14 at 14:35
I just yesterday dealt with one like that. It had electric ignition (glowing ignitor) and a single yelloow "flame sense" wire. This is only the second one of these I've found in a decade, but the problem and the solution is the same. IF your unit uses ion flame detection, the burner ground has become oxidized. It may look like metal against metal, but a fine coat of invisible oxidation had formed between the metal parts. It needs a good "ground reference" before it can detect the ions.
To fix this, I removed the burner. While I had it out, I scraped the flame rod tip some but it wasn't really dirty. When I put it back in, I intentionally made one of the self-tapping sheet metal screws dig a new groove instead of putting it back in the first grooves. I also got it good and tight.
Just as in the first case, the mere act of disturbing the mechanical assembly caused a better ground to be formed. It must be working, because I didn't have to get up last night and go fix it.
  • I think it was only from cleaning the sensor; it's (still and has always been) isolated from ground or you have defeated its purpose. – Mazura Mar 28 '15 at 23:54
It could also be a simple matter of the vacuum tube in the unit having some small debris in it. Mine does this now and then. You're talking about a power vent to the outside correct?
