The flange is about 7" OD. As you can see both slots where the closet bolts would go are broken. Can I salvage this flange somehow, instead of having to rip it out of the concrete and installing a new one?
flange
They make toilet flange repair rings. I don't have any personal experience, so I can't say how durable they are, but for a couple bucks it's worth a try. You can see that there are holes to screw through the plastic flange holes, so in your case I'd get a good concrete bit and some tapcon screws.
sample image from homedepot.com, no affiliation
  • Using a similar ring worked. Four 2.25" tap con screws and one can mount a 50mm cannon on top of it.
    – Nikita
    Commented Jan 4, 2015 at 8:29
I think it's toast. Even if you could salvage it, you'd probably regret it later when the toilet starts rocking and leaking.
Do it right, replace it.
You just need to remove a small amount of concrete around it, shouldn't be much work with a chisel.
  • Hmm. There is no repair ring I could install on top?
    – Nikita
    Commented Dec 21, 2014 at 16:33
