I'm installing laminate flooring in a bedroom next to a tiled hallway. I'm planning to have a standard expansion gap all the way around the room, but I'm stuck on how to do the doorway. I know the standard approach is to use T-moulding, but whoever did the original floors in my house just used a thin metal divider between the engineered hardwood floors and the tile. I'd like to be able to install the laminate the same way without a gap for just the length of the doorway. The room is 10' x 11'. Am I going to run into problems?
I haven't noticed any expansion issues with the engineered hardwood floors, and they seem to be blocked in on several sides by these transitions. The living room has a 17' wide section with no expansion gap between doorways on either side. If it matters, the house is on a slab.
