What if my incoming source starts at the outlet I want to split (always on for the dishwasher, switched for the garbage disposal) and not in the switch/outlet combo? How would I wire that?
I read this and looked at the diagram on your site:
If you want to have power always on to a box that is downstream of a switch, you'll need to use 3-conductor cable between the switch and split the hot side of the outlet.
At the outlet, break off the tab on the hot side only between the top and bottom outlet. Wire the red conductor to one of the hot screws, the black conductor to the other one, and then the white to the other side of the outlet.
At the switch/outlet, you'll need to wire the incoming black wire to one of the hot screws, and the outgoing black wire (to the 3 condutor cable) to the other hot screw. The outgoing red wire (the one controlled by the switch) goes on the neutral side of the switch, and the incoming white wire gets wire-nutted together to the neutral side of the outlet along with the outgoing white wire (from the 3 conductor cable)
Be sure to ground all outlets and switches as well.
I think its image #6?
