I have a stackable washer dryer combo. The dryer works on 240V and the washer works 120V, but they have 1 control panel. I don't have 240V in my new apartment, and am hoping to have the power cord switched to a 120V. I have read that this process involves:
- getting a 3 wire 120 cord-set of at least 14 gauge and a 14 gauge jumper wire.
- connect neutral to neutral terminal
- black to black terminal
- ground to ground terminal
- and jumper wire from neutral to red
I have no experience with electronics and don`t plan on doing this myself, I had an electrician come look at it for me but he has never done it before, my question is:
Does this look correct, can he or (most likely another electrician) do this? I know it won't be code, I just need to know if it's possible.
