When we bought our house, the lighting fixtures in the ceiling came with R20 bulbs. I know nothing about lighting so I figured that only R20 bulbs are compatible with our fixtures. But I'm realizing that may not be the case.
So what are kinds of bulbs can I use that are interchangeable with R20 bulbs?
More specifically, I'm interested in Philips' Hue bulbs
Are any bulbs from that line compatible with lighting fixtures that accept R20 bulbs?
These would be the equivalent of an R20 flood lamp: enter image description here
R20 is simply a lamp size and style designation. R for reflector lamp. 20 for 20 eights of an inch, or 20/8", or 2.5" in diameter.
Just know, standard "A-lamps" will fit similarly to R20 lamps. It's just R lamps are reflector and will concentrate the light basically in one direction, while A lamps glow all around. The design of the fixture will determine what lamps will work best.
  • @KhoiVinh And of course observe the fixture wattage limits.
    – derobert
    Commented Dec 11, 2014 at 22:49
