I have the compressor which can be seen below and I would like to connect one of the the two Alligator Compressor Nipples.
Question
Will the hose work with the first nipple?
Does there exist a special hose for the second nipple? Or does there exist a converter?
You are going to need an adapter to get the hose attached to the compressor, then another adapter to get the compressor nipple attached to the hose. The adapters look like this:
This nipple comes in a variety of sizes, so you have to match it for intended usage. This nipple will go into the coupler on the compressor and female threaded end would be attached to the top end (as looking at the picture) of the hose. You'll need another similar nipple attached to the end of the tool end which looks like this:
Picture salvaged from mscdirect.com
You'll notice the big difference here is that it has a male threaded end. This (obviously) will go into the female threaded end on the tool.
These adapters can be made out of brass, aluminum, or what have you. For best results, I've used Teflon tape around the threads to minimize air leakage.
