I am adding an outdoor wood burner (water stove) to my home.
Water to air heat exchanger plumbed into existing ductwork for oil burner.
What are my options for running the oil burner's fan WITHOUT the oil burner firing and attempting to heat?
Could it be wired with a toggle switch in line at some point, as I have no plans to purchase oil at the current prices?
Just set the thermostat to the off position and turn the fan setting on the thermostat to "on". Your fan will run continuously until you set it back to "auto".
| improve this answer | |
