We moved into a new home about one year ago. Since then we have had several weird instances where several light bulbs within our home burn out at the same time. My wife has also had 2 high-end salon grade hair dryers burn out during this time as well. Thankfully nothing really expensive has blown out yet but I became concerned that we may have a problem so I started doing some research online.
I eventually called the power company to request a line check. The line check revealed a voltage imbalance on the 2 hot lines into our home so the power company tech informed me that he had to shut down my power as a precaution until a repair crew could come identify/repair the problem. The repair personnel showed up a few hours later and it was dark and getting late. Unlike the earlier technician who arrived in a power company truck the repair crew appeared to be driving non power company vehicles so I believe they were subcontractors. They claimed they ran some current tests on the lines and found no problems. They told me they couldn't fix a problem they couldn't find so they were going to turn our power back on.
This didn't make sense to me so I asked a lot of questions about why things were burning up and what would cause the imbalance and I didn't get any clear answers. It also didn't make sense to me that the power company thought it serious enough to shut down our power as a precaution only to have the repair crew tell me there was no problem. My gut was telling me the repair guys were short cutting something but I don't know enough to be sure. Any advice on what I should do would be greatly appreciated.
