I'm planning to install new laminate flooring in a bedroom that has two closets, and I just want to make sure I'm orienting it correctly. From what I've read, there are two rules for this:
- Along the longest wall of the room
- Perpendicular to the highest source of light
I am only able to follow one of these rules for this room. Please take a look at what I'm planning so far:
Here, I have the laminate along the longest wall of the room, and I'm planning to use T-moldings at the closet doors so the laminate is along the longest walls in there as well. Is this a good way to lay it out, or is there a better way?
