I have an aluminum garage door that looks in great shape; the only problem is one of the brackets in the middle of the garage door broke. I thought someone would be able to weld it back together, but a garage door company said the whole door needs to be replaced.
Is that true? Can't a bracket on an aluminum garage door bracket be fixed without replacing the whole garage door along with permits?
    Do you have any photos for us? Even if you can't weld it you might be able to rivet or screw replacement hinge backing in place.
    – dkwiebe
    Commented Dec 3, 2014 at 23:51
You can buy most common parts separately. Replace the part rather than have it welded. Ask at your local hardware store (NOT "big-box" store) for a handyman reference, someone familiar with garage doors. Garage door companies will almost always recommend a new door.
Hey, while you are at your local "mom and pop" store, why don't you pick up a few items and help them stay in business?
