I am currently redecorating the hallway and stairs and at the front door and landing window we get quite a heavy amount of condensation build up around them.
When painting I have noticed that the area's nearest the window and door frames are still wet to the touch. The areas where previously glossed but I sanded them down with 40 grit and after feeling the area they where keyed up and looked to be gloss free.
Is it just taking longer to dry due to the cold/wet air that are around the window and door? Would pointing a blow heater aid in the drying process to speed it up a bit and actually let it dry?
Cheers Mark
