This is probably a total newbie question, I apologize in advance.
I have two pipes, hot and cold; I'd like to set up a single control point that turns the flow on both of them on or off, at the same time. I've been scouring the internet but I just can't find it.
Requirements:
  • I don't want a thermostatic mixing valve - I need the output to still be two pipes, hot and cold.
  • I don't want two knobs. Two knobs would be an easy solution but not the one I need cosmetically.
    What exactly are you trying to setup? That is a fairly odd configuration, it would be helpful to know why you want it that way. – Grant Nov 21 '14 at 4:39
    Clearly this is related to your other question – gregmac Nov 21 '14 at 8:13
  • I've certainly never heard of a valve that has two separate in/outs like you're describing. However, I am thinking about this being possible using solenoids.. but safety is an issue. – gregmac Nov 21 '14 at 8:21
Laundry Shut-off valve - any hardware/plumbing store or the internet.
Valve image from home depot, just as an example.
  • Of course, it might be nice to find a version which is designed to be plumbed in on both sides rather than having hose threads. Then again, I suspect that someone makes an adapter you could solder onto the threaded end to covert it back to a soldered connection. "If it happens, it must be possible." – keshlam Nov 21 '14 at 14:25
Never heard of such a thing. But off the top of my head, you could mechanically link two hidden conventional spigots. I'm imagining a faucet handle connected by a shaft to a conventional toothed gear. That gear is meshed to two additional gears each of which is connected to a spigot. Turning the one faucet Handle then operates two spigots. Far from off the shelf and may be a pain, but should work in principle.
That is just a shut-off valve.
