I recently purchased a 2050 sq ft. house 1 story, built in 2000, in North Dallas. We had a general inspection done on it, and the disclosure didn't mention any foundation issues, also all the doors close right, and so do the windows, walking thru the house it is really hard to find a spot that actually feels uneven when walking, in fact there is only one in the hardwood floor. The floor is about 50% hardwood floor, 25% concrete and 15% tile and 10% carpet. On the room with carpet everything sits right everywhere, I imagine because the carpet softness makes everything level easily.
However I have noticed small pieces of furniture such as chairs, or anything where the legs are not too far apart for instance my nightstands are also not leveled by about 1/6 inch, often only sits right if you put in the "right" spot, otherwise the legs are not leveled by up to 8 milimeters (.31 inches in the worst case) often a lot less. And sometimes the chairs sit just right, this is not a problem with large furniture as I suppose the legs kinda level themselves out with the weight.
I was however wondering if this is something I should be concerned about, or if this is something relatively normal for a 2000 house, there are no slopes anywhere, it is mostly really small variations here and there, which can make a chair not sit right in some spots. Usually those spots are closer to the wall, but not always.
The house has rain-bird sprinklers around the foundation, and I make sure to water it but not excessively of course, also everything is sloped away from the foundation.
We saw several houses before buying this one, and this one is actually the one where the floors felt the most leveled, so I am guessing this is somewhat common in houses between 1990 and 2005 (the houses that we saw) that have settled a little bit, which is my understanding is also normal, as all houses settle after being built.
For reference I used to live in Mexico, in a pure concrete house like everyone else there, and uneven floors where never an issue, everything was always perfectly leveled.
Should I be concerned?, or should I be doing anything about this?
