My concrete flat roof is 2 years old. Above the roof I have fixed terracotta tiles. During heavy rains I find water leakages (dropping) inside my house in several places. Water drain is perfect. No water stagnation after rain stops. I couldn't find any cracks, holes in my roof. Kindly suggest me how to find out the exact leakage point. I would be ever thankful for your valuable suggestion. I want to get rid of this problem.
pull up the tiles and see if the water proofing is damaged – ratchet freak Nov 17 '14 at 11:38
If it's in several places, I'd say this isn't something you just want to patch. Sounds like an overall failure of the roofing system. Might come down to a full tear-off and redo, unfortunately. – DA01 Jan 16 '15 at 21:54
Go into the attic next time it rains. Look around for a leak above the places it leaks in the house. Additionally, sometimes leaks will "travel down" a rafter a bit before dripping down, so check your raters for water trails, and follow them!
3I have never seen roof leak that did not travel quite a distance from where the leak was found. Good luck! – Evil Elf Nov 17 '14 at 14:02
