My family just moved into a new house and it's awkwardly laid out. We are planning on moving in another year or two and we want to fix up the house enough to profit from it, but to also make it as comfortable as needed. Therefore price is a real concern.
One of the plans we came up with involves moving the front door to the other side of the front room, a move of about 17 feet. We would be covering up where it is at the moment, and cutting into the house on the other side to create enough space for the door + a small porch step. Our house is older, made probably in the 60's or 70's, therefore we know there might be some structural difficulties.
Is it possible to move the front door without it eating up too much money? Or is it really just based on the structure of the house?
    Pictures would help.
    – DMoore
    Commented Nov 14, 2014 at 15:34
A front door is just a controlled hole in the wall. But it is very controlled. You are right to think that there are structural issues. The wall where the door is located has several of its upright structural members (studs) removed. There has to be a horizontal support (header) added to make up for that, and extra vertical supports under that. The exact size depends on span and what is over the new door area. You may need an architect or engineer to confirm the ability to bear the load above.
There is also the issue of sealing against weather, both air and water. Flashing, insulation and a variety of seals are needed to keep the outside outside.
Finally, the entry landing has to be appropriate. If above grade, adequate steps or decking is needed.
Since you are asking, it sounds like this is not a do-it-yourself project that would be within your comfort zone. You may want to get a contractor in to give you an estimate.
It's almost certainly possible... basically you're adding a new door, then closing up the old one, both of which are fairly standard operations during renovations.
Assuming a wooden-framed house, your place is recent enough that it's probably very straighforward. Should just be a matter of opening up the wall surfaces, framing the doorway (properly) to replace (part of) one of the studs, dropping in a prehung door, opening the area around the current doorway, taking the door out (you might want to do this first, if you want to reuse that door and the carpenter says that can be done), and shoving in a partial stud to fill the cap. Close the patient and paint. I hesitate a bit to suggest DIY since outside walls are loadbearing, but in theory this isn't complicated.
I can't advise re other building materials; hopefully someone else can do so.
In any case, I would suggest that you Call a few construction/alteration folks (a good contractor can be very helpful, though a bad one can be a nuisance) and get quotes.
(Here, where "middle aged" houses are in the 100-year-old range, there's a wider range of construction techniques, lots of settling and past alterations, and things can get somewhat more interesting. I've dithered about adding French doors to my porch because I'm not sure we could do that wide an opening without putting in a Paralam beam to make sure the load's supported properly.)
  • Looking at your answer, how was it determined that the building's walls are not CMU, brick, or concrete?
    – user23752
    Commented Nov 14, 2014 at 14:01
  • Sorry; I'm biased since stick construction is predominant in housing in much of the US. Adjusted appropriately.
    – keshlam
    Commented Nov 14, 2014 at 15:43
  • In swaths of the US masonry construction is very much common - CMU in South Florida, brick in many older urban environments. In other parts of the world served by the internet, concrete construction may prevail.
    – user23752
    Commented Nov 14, 2014 at 16:13
