I just had my water heater replaced (by a professional) and everything is great except the bathtub fixtures (shower head and tub faucet) in just one bathroom. The water pressure is really low, especially when it's turned to hot. Every other fixture in the house works fine (even upstairs).
I took off the tub faucet fixture to see if sediment had accumulated in there, but when I turn on the water and watch it come straight out the piping, I see the same thing. Decent pressure if it's on cold and slows to a trickle when turned all the way to hot.
I'm getting the run-around from the installer and don't want to call a plumber if I can fix this myself. I can see almost the entire run from the heater to the tub, which is all copper piping, and I have access via a wall panel to the fixture from behind the tub.
