Background:
I noticed that light bulbs in our house burn out too frequently. We don't get even 1/4 the life-span that is advertised. This is frustrating.
Some ten years ago when CFL's came, I tried them and was disappointed completely. The cost was much more than the regular ones and the life-span did not change much either.
When I asked a Home Depot associate he said, it is likely that our house has Voltage spikes and that is contributing to the low life of bulbs. Sounds like a reasonable explanation. He suggested I try 130 volt bulbs. I think the bulbs are lasting longer.
Question:
When I plugged in a regular 130 volt bulb into a recessed light socket (this has Br-30 or Br-40 bulbs) I noticed that the bulb won't light. When I used the same bulb in a regular light socket, it will come on.
When I tried 120 volt Br-30 bulb the recessed light socket, it came ON. This suggests the socket is working.
Can someone explain why this could be.
Could someone recommend a 130 volt Br-30 / Br-40 bulb.
