I had some water damage at the base of a wall. I ended up tearing out the bottom half of the wall, about 55" high. I now need to close it back up.
The wall that I tore out is about 3/4" thick. It looks like it is 3/8" drywall with a healthy dose of plaster on top. What's the best way to butt another sheet of drywall up to it?
I have never plastered before, so I'd like to avoid that as much as possible. I'm thinking that I can just put some 1/4" shims/plywood on the studs, then screw some 1/2" drywall to it. The only question that leaves open is joining the edge of the drywall to the plaster.
The edge of the plaster that is still in place is not terribly clean. It's ok in some places, and other places it will leave a ~1" gap when I butt the new drywall against it. I'll assume that I'll need to fill in the gaps. Will joint compound suffice here, or should I pick up a small batch of plaster?
(As an aside, I should add that most of this work will be hidden behind cabinets. Only the top few inches of the work will ever be visible.)
