I have 4 lights outside that are all wired to 1 light switch inside.
What is the best/cost effective way to put all these lights on a timer?
Sign up to join this communityI have 4 lights outside that are all wired to 1 light switch inside.
They are now making in-wall single pole timers that do not need a neutral wire, for older homes that don't have a neutral run to the switch boxes. Should be easy to install (as long as your switch box is not too crowded).
