I am replacing the seat on a RAK Flora toilet . The replacement parts have a bolt, to go down thru the porcelain, then a plastic wing nut, metal washer and another plastic bit which just slides along the bolt. My question is, what order do I put those 3 onto the bolt? Should the washer go against the porcelain or between the 2 plastic bits?.
Asked
Viewed
636 times
Did the seat come with instructions? What do they say? – Tester101 Nov 2 '14 at 12:17
RAK Infinity Seat This is the only seat shown that has the same style hinge point. The above replacement differs quite a bit. – Fiasco Labs Nov 2 '14 at 19:27
There were no instructions and the RAK site doesn't have the exact same seat, the replacement is a 'new' version. I think I'll just call a plumber/ builder to install it. thanks! – Pip Nov 3 '14 at 7:01
