how far below the Mud line on a stucco home do you need to be to avoid water issues 1", 2", 3" or more
  • What is this concrete used for? Is it intended to be used a sidewalk or patio? – Jason Hutchinson Oct 29 '14 at 13:05
None. The concrete should slope away from home. If you have the option to go an inch down then fine so you don't mess up the stucco while pouring.
  • Concrete, or any large flat surface, should be sloped away from the structure at a rate of 1/8" to 1/4" down vertically for every linear foot horizontally to provide sufficient drainage. According to the ADA guidelines, the maximum slope shall be no more than 1" vertically per linear foot horizontally. – rjbergen Oct 29 '14 at 13:16
