I have a brick house and my wife and I want to install plastic shutters and wooden window boxes on some windows. I know that the shutters will not be heavy load bearers, but the windows boxes will be much heavier.
I've looked all over online and am still pretty confused by the differences in the masonry anchors that I might need to use for this project.
I see tapcon screws are anchors and screws in one, but would they be strong enough to handle a window box?
Are there standard plastic/metal anchors I could use that would work just like a drywall anchors?
  • Do you own a hammer drill?
    – Mazura
    Oct 28, 2014 at 5:09
  • I do not, I've been told that a regular drill will work, but take longer.
    – Eric C
    Oct 28, 2014 at 12:58
  • Depending on how hard the masonry is (common brick is soft, glazed will be more difficult), it might just laugh at you. Also, you may need a whole pack of drill bits. Tapconing into a mortar joint is to be avoided.
    – Mazura
    Oct 28, 2014 at 21:38
  • Any reason you say tapcon shouldn't used on a mortar joint?
    – Eric C
    Oct 29, 2014 at 4:46
  • It's real easy to ream the hole to large while drilling into mortar; pullout strength will be degraded either way. However, without a hammer drill, that's probably where there going to have to go. Some planter boxes? Sure. Your 60" TV? No.
    – Mazura
    Oct 29, 2014 at 4:54
Tapcons <(Stack Exchange discussion) will do the trick. Just use enough of the right ones and some washers. Do not use plastic anything. Personally, they're my favorite and I dread making the holes for these, wedge anchors, when I need something to be structural.
Recently I've begun using these, Wedge Bolts instead, where something better than a Tapcon is necessary: (all fasteners shown require a hammer-drill and a masonry bit to drill the hole, and I highly recommend using an impact gun to drive them)
