Any one know how to open this screw?
Tried pliers but no avail and standard box of security screwdrivers couldnt open it. enter image description here
Here are some more photos
4 Answers 4
Those are external line head screws, and are used as anti-tamper screws in some Japanese electronics. You can probably find a driver for them from a game console hack supplier (they're used on Gamecube, Wii, and some other game consoles). The driver looks like this (sorry for the horrible pic):
They also come in 5 and 7 point varieties (hard to tell how many points from the picture you posted). I've also seen them called torx inverted.
If you don't want to get a specific driver for them, you can probably get them out by clamping on the head really hard with a pair of vise-grips or use a screw extractor. You might be able to find a socket that will mesh with them well enough, but that's a long shot.
    Looks like possibly a watch crab or adjustable spanner (where spanner means specifically "two-pin style") wrench might be made to work. There's also always the option of welding a nut to them ;-)
    Oct 24, 2014 at 2:54
If it's a screw, a couple of ideas:
  1. You can use a dremel to cut a slot in the screw head and then use a normal screwdriver on it.
  2. Get an old toothbrush. Head up the handle with a lighter or a heat gun. When it gets hot, press it over the screw head. Hold it until it cools. That gives you a custom screwdriver. Press hard when you use it.
It looks like a rivet, in that case you will have to cut it off or try to pry the head off.
It also looks like it has 6 tabs, you might be able to get a 6-sided socket on it and break the head.
You can use a pipe wrench for this. If you use it "downwards" the wrench tightens itself on the screw. It is a little tricky because you have to make sure the wrench stays on the screw of course.
