I want to fix our pedal bin into the kitchen cupboard such that when the cupboard is opened, the bin will pivot out (preferably with lid open) - i.e. imitating a commercial product (just as a random example of the mechanism I'm looking for, not an ad!). (Google has let me down completely; I found a few DIY tutorials on pull-out versions of the general idea, but that just seems too involved besides not being quite what we're looking for.)
Our pedal bin is (I'm guessing) a 50L bin. Commercially available solutions generally offer only around 12L bins, which makes me wonder if the swing-out-bin idea is even feasible with a 50L-sized bin? (And we don't want a new bin, the one we have is perfect at its job. It's just a pain to throw things in it where it's hiding in its cupboard.)
If it is feasible, what might be the best (by which I mean simplest, cheapest, not requiring buying fancy new bits...) way of going about it? I'd imagine the bin, especially once full, would be too heavy to be hung on the door of the cupboard. Commercial solutions (like the example above) suggest using a rod fixed to the inside of the cupboard which is to carry the weight of the bin, and rotates as the door pulls out the bin? Bearing in mind we have no power tools apart from a simple drill, what would I use for such a rod and its fixings? As for the lid, would you counsel removing the lid from the pedal bin, and fixing it to the inside of the cupboard (as in above example), to close over the bin when it is rotated into the cupboard, or leave it on the bin as is, and have a pull-string pull the lid up as the bin swings out the cupboard?
The bin measures 63 cm high (with lid closed, 59 cm without lid), and approx. 30 cm in diameter. The cupboard is 36cm wide, 49cm deep, 68.5cm high. (I.e. the bin fits inside it comfortably, but there's little space above it to get it open and stuff things inside, which is what's driving me insane! NB We do need the lid to keep the smells down.)
  • Trying to fashion actuated hardware on a budget with a skeleton tool set... that's an uphill battle. Are you able to do some cabinet modifications and a bit of light carpentry?
    – user23534
    Commented Oct 23, 2014 at 0:27
  • Yes, in principle - what are you thinking of?
    – crs
    Commented Oct 23, 2014 at 10:58
  • Let me do some sketches and I'll get back to you later today.
    – user23534
    Commented Oct 23, 2014 at 13:45
Okay, bear with me here. This may look a bit daunting but as far as the construction goes it's all pretty basic. The precise measurements and movements of things are another story. The depth of the cabinet relative to the width of the can will be important because there must be enough throw between open and closed to make it all work. And the distance the arm can descend has to be long enough to open the lid satisfactorily. The weight of the arm has to be heavy enough in the open position to counter act the mechanism of the can but not be so heavy that it snaps it to and fro harshly. And all this is assuming you have a can that's built like this one and the cabinet it goes in is adequately sized to accommodate all of the parts required to pull this off.
If you have a different kind of can I think the basic concept can be adapted to work for most types. I chose this one because it's actually the trickiest to actuate. If you can't shoe horn a carriage into the existing cabinet around the trash can...this idea might be dead in the water. The depth in particular is critical as it must be great enough to accept the can plus the length of travel the lid requires.
  1. First construct a carriage for your can that rides in and out on some 100lb, full extension, side mount drawer slides like these.
  2. Remove the hinges from your the door of your cabinet and attach it to the front of the carriage so it comes straight out and back instead of swinging aside. enter image description here
  3. Next attach a bushing and keeper to the cabinet wall. A piece of 1 1/2 pvc would make a good bushing. (seen in blue) Make sure there's enough space between the bushing and the keeper block to allow the arm to pivot. enter image description here
  4. Now attach a strap of ballistic fabric (cut up an old ratchet strap maybe) to the lid of your can with a rare earth magnet or some other removable means so you can get the can out easily for cleaning. Run the strap to a counter weighted arm. You might have to experiment with the weight so you'll want to be able to add and subtract mass. Lead weights like these would be great. enter image description here
  5. Attach the arm to the back of the carriage with some sort of articulated knuckle (two eyelets hooked together would work). If all goes well, when you pull the door/carriage out the weight of the arm will pull down on the strap, opening the lid. As you close it, the arm will be pulled back in and the lid will close itself as its designed to do. enter image description here enter image description here This all may take a bit of trial and error but I believe it's doable for minimal cost out of materials that could be bought at any hardware store and it requires no special tools. If you do get it all to work please post a follow up, I'd love to see pictures of it in action! Cheers.
Or you can use a pipe necklace (if your bin is round) or another system. If it's not, try to stick the bin to the cabinet door. I am building one and this is how I found your post. My bin is round and I am going to take pictures after I finish my project.
PS: a string is going to open the lid.
