I have just moved into a new apartment and I found the toilet does not have a very powerful flush. After thoroughly cleaning the entire toilet – inside and out –, checking the water valve is fully open, and tank water level is correct, I still found the toilet to not flush properly.
I believe I have traced the issue to grime and dirt under the toilet rim that must be clogging the rim jets. I tried a few different household cleaners with a toilet brush as well as pouring vinegar through the overflow tube. I have removed quite a bit of the dirt; however, about 35% of the toilet rim still does not provide water when the toilet is flushed.
As many online guides suggest, I tried to use a mirror to look under the rim of the toilet and a wire to clean out the jet holes. However, the space between the bowl and the rim is quite narrow and I am unable to see any jet holes under the rim even when using a good mirror and flashlight. I do see a lot of dirt however and I cannot seem to get rid of it. Does anyone have any suggestions on how to restore full flushing to the toilet despite the hard to reach area under the rim? Is it possible that this toilet does not have any flush jets?
