So, builders have this thing, for some reason, of installing cement parking blocks a few feet in front of the hot water heater in the garage. I've lived at plenty of places without those and managed to not drive through the water heater into the wall. Maybe I'm just abnormal like that.. (I did check the code [USA - Florida] and didn't see any requirements for this block)
Anyway, this thing is in the garage. The garage is an enclosed, attached garage with a door that goes into the house. This parking block is in the way of a project I'd like to do.
I shined a light down the holes in the parking block and did not see any rebar stakes. I poured water down the holes where the rebar should be but it didn't drain out from under the block, so I imagine the thing is cemented or sealed to the floor.
The floor is concrete as well. How would I go about trying to remove this thing without damaging the garage floor under it? I thought maybe a sledge hammer and a hammer drill, but I don't know if this is a good idea. Maybe a saw? Maybe the attaching material can be dealt with another way? I don't know, but I figured I'd ask..
