I'm installing a light pendant. Its wires are white, green, black.
My ceiling box has wires that are white, green, red.
I've attached white-white, green-green, black-red.
two questions: 1) assuming black and red go together, is this correct? 2) green-green is secured by wire nut, bypassing green screw. Or should both be wound to the green screw?
addendum: I had a leftover 6 inch red wire (from a previous endeavor) so I stripped it till it was bare, and used this to wind to both ground wires (from source and pendant) into the wire nut and then attached the other end of the bare wire to the green screw.
