Approximately 3 years ago I purchased a slice of a log, approximately 50 cm (~1.5') wide at the widest place, approximately 2.5-3 meters (~9-10') long, and about 4-5cm thick (I don't have exact measurements with me right now, will add them in a comment later, if necessary and will add photos if necessary, also later). I think the wood is pine, but am unsure at this moment. The piece was cut into two pieces (~2m and ~1m).
One was treated (by me) with an oil based coating ("Yacht Varnish") with two or three (can't remember now) fairly thick coats, from all sides. I don't know whether this is a mistake or not (let me know!) but I did not fill the imperfections first, but rather tried to put enough of the varnish to coat them as well.
The other, after some time, was treated with two coats of water based laquer which gave is a nicer matte finish, in order for it not to be exposed to the elements.
The long piece was attached at the ends (screwed with 2 corner joints on each end, such that it was resting on the joints) to a wall and a concrete column. The shorter piece did not find a use.
After about a year the shorter piece developed a crack along the middle, with the grain. I did nothing about it. After we moved I turned the bar piece into a bench by screwing 4 feet into it. I did not remove the corners from the wood as I thought it might ruin the thread there, and allow moisture to enter the wood (planned to use them to add hand rests at the ends).
Despite the fact that it felt very sturdy and that people sat on it a handful of time for a total time of maybe an hour, the board developed a fairly wide (3mm I think, at its widest) crack along the grain, around the middle of the bench.
So, I have two questions: 1. I presume I treated the wood badly or this would not have happened. What should I have done differently? 2. What can I do now to stop the crack from spreading and to make the bench safe for sitting without fear of breakage? Most of all I want to avoid sanding it again as I don't have the proper place to do it and don't want to breath wood/lacquer dust.
In regard to Q. 2, I thought about adding a frame undernear, shaped as H or as a rectangle. I thought that maybe the crack didn't develop earlier since the corners did not allow the wood to expand, and now that there is nothing holding them, it did expand in an uneven manner? or perhaps that the presence of the corners did not allow the ends to expand with the middle, and it was bound to happen anyway, with the way it was affixed?
Thanks in advance for all the answers!
Edit:
Just measured: The cut piece is ~1.5m x 40cm x 4cm. The largest crack is about 1 mm wide and 50cm long.
Photos:
The crack at the end I think has been from some time after cutting the smaller part off and before the varnish:
(http://i.imgur.com/CgnBjeM.jpg)
First part of the crack (it is one long crack with varying width):
(http://i.imgur.com/AeAREE3.jpg)
Second part of the crack:
