We have a flex-bit stuck in wood - tried to drill it through the ceiling and the shank (bottom part of the bit) stripped so now it can't be "locked" to the chuck of the drill. Is there any way to adapt a stripped shank/attach another drill bit/shank to it?
Follow up question - if you couldn't get it out - who would be the professional you'd call?
