I have a new Leviton Decora Switch with built in pilot light (Catalog # 5618-2W). I want to replace a switch currently connected to two black wires. Three sets of wires come into the box. Each set consists on a black, a white and a ground wire.
I know the ground wires go to the green screw.
On one side of the switch I have a black screw and a brass screw. On the other side I have a silver screw.
You'll start by connect the grounding conductor to the green screw. The black wires that are currently attached to the old switch, will attach to the black and brass colored screws on the new switch. Finally you'll have to locate a grounded "neutral" wire; or group of wires, within the box. Using a twist-on wire connector, connect a short bit of wire to the grounded "neutral" wire(s). Connect the other end of the short bit of wire, to the silver screw on the new switch.
Wiring
    In the diagram, the L outside the box is the fixture or outlets (Load) that are controlled by the switch. The L inside the box is the lamp that is on when the switch is on.
    – bib
    Commented Oct 9, 2014 at 19:43
  • @bib Thanks, I'll update the image when I get a chance.
    – Tester101
    Commented Oct 9, 2014 at 19:46
