My house had a new gas central heating system fitted, with new radiators, before I moved in. One radiator (in the tiny downstairs WC) is missing the control knob for the TRV, and is set to the highest setting. I vaguely remember seeing somewhere that this is desirable for some reason, but it is far too hot for such a small room.
I haven't been able to find a replacement control without the entire TRV, so is it safe to lower the heat using an adjustable wrench or something?
Until you get it replaced you can adjust the radiator temperature by adjusting the balancing valve on the other side of the radiator. Open the plastic cap and use a adjustable spanner and close the valve clockwise as necessary! good luck.
-unicuk, How to replace a Thermostatic radiator valve (broken Head).mp4 , YouTube
As I understand it, TRVs operate by depressing the little pin, in increments. You need to check this for free movement before buying just a knob replacement. The nut your probably looking at would disassemble the TRV. Look for a valve on the opposite side and turn that one.
This is from research, not experience, good luck.
  • After reading your answer I think the end that would have a TRV is actually covered up, and I'm looking at the balancing valve. Thank you!
    – conradj
    Oct 10, 2014 at 7:56
I think on some systems at least one radiator should remain open to provide some circulation - maybe for the sake of the pump. This valve wouldn't have a TRV or the setting would be very high so it wouldn't ever close fully. Would that be why it's covered up?
The tiny radiator would be a good choice as it would dissipate and waste least heat.
    Correct as to why you need one radiator always open. As to choice of which one: the best is the one in the room which has the house thermostat; the house thermostat therefore shutting off supply to that radiator (and all other radiators) when that room is warm enough.
    – AndyT
    Nov 27, 2015 at 10:14
  • If the heating system has a weather control (temp sensor outside), the best choice for free flow radiators will be all the bathrooms, as these are the rooms we want warm all the time.
    – Thomas
    Nov 30, 2023 at 11:08
