I have a container of dried out drywall mud and I wondered if there is anything I can do to make it usable again.
Not an answer, but general advice: if you buy a 5 gallon bucket at <home improvement warehouse> it comes with a plastic sheet to cover the mud. Leave that in there: when you are done getting mud out, tamp it down and ensure it covers all the mud. Then close the lid and make sure the lid is on tight: it should have several parts on the rim that click into place. Finally, leave it open for the minimum amount of time necessary: scoop out a bunch of mud into your mud tray and close it right away. The less time it has to dry out, the better. – user4302 Dec 13 '15 at 4:35
Going off the above comment from User4302, you can also use plastic wrap (like for sandwiches) as a "topper" in your pail. We did this when I used to sell/deliver drywall products for damaged product that we would either put on clearance (at a stupid discount) or take home for our own uses. – J Crosby Jun 7 '19 at 22:50
Drywall mud is so darn cheap, why would you do this?
That said, I actually tried this myself one time because I was temporarily without a car to get to the store, and I was impatient. I managed to get it to a somewhat workable consistency, but no matter what I did, I couldn't get the lumps out of it. I think if I'd let it sit and re-hydrate over a longer period, perhaps I could have worked out the lumps. But by that time, I'd have the car, and I just threw the lot of it away.
2I don't think it really can be rehydrated - it's a latex product, and once hardened, it's hard. +1 for toss and get a new bucket. If you were in desperate need of smooth drywall on a desert island, you could perhaps add water, stir, wait, and then push it through a screen to remove lumps, but any lumps smaller than the screen would pass...and why would you be you stressing about smooth drywall on a desert island, anyway??? – Ecnerwal Oct 3 '14 at 23:51
For the price of drywall mud, I am pretty sure the bucket itself costs as much as the mud. – user4302 Dec 13 '15 at 4:36
While you can rehydrate mud, the rehydrated stuff you make will not perform acceptably.
The reason is in the binder, the stuff that makes it harden and stick to the wall. This is usually polyvinyl alcohol (PVA). For reference, see the USG Sheetrock all-purpose joint compound MSDS, which lists "vinyl alcohol polymer" as an ingredient.
PVA is water soluble, but by the time it has dried, the polymerization reaction that makes it work as a glue has already happened. Getting it wet then somewhat reverses this reaction, but not completely. Even if you get all the lumps out, at a microscopic level you will still have a lot of polymerized PVA and other products of the reaction. You will essentially have drywall compound where a significant portion of the binder has already "dried", so when your rehydrated compound dries again, it won't bind as well as it should.
As a result, you will get poor adhesion to the wall, and likewise paint will not adhere well. This case study (now paywalled, see archive.org version) examines a case where the drywall contractors thinned excessively new drywall compound and got a similar result. While not exactly your case, it should demonstrate how the curing reaction in joint compound is not simple drying, and can be broken by deviation from the proper conditions.
Nice analysis and +1 for the case study link. I think this should put to rest this and any future discussions on this topic or on altering/thinning drywall mud. @Phil Frost, I am curious as to whether you could give a quick breakdown on the difference between joint compound and topping? – Jimmy Fix-it Oct 4 '14 at 16:01
@JimmyFix-it, my understanding is that topping compound has less binder and is designed to be mixed thinner. Some people like working with thinner mud, as in the case study. I'm not one of those people. The tradeoff for a thin consistency and easy sanding is a less durable bond, so you wouldn't use topping compound for embedding tape. I use general-purpose mud (green lid) or hot mud all the way through. When I've used even the "lightweight all purpose" (blue lid), I've found paint adhesion to be poor, and I find the all purpose mud sandable enough. – Phil Frost Oct 4 '14 at 16:37
thank you sir; I have always used all-purpose throughout but was unsure what to tell people about topping, now I will tell them "not for taping, only for finish", thanks again. – Jimmy Fix-it Oct 4 '14 at 21:01
Unfortunately you cannot re-wet drywall compound and get a usable product. It will break down in to a rough slurry, but the consistency will never be smooth enough to get a descent finish.
I have to admit, however, that's where my knowledge ended, so I had to ask myself... why? Why doesn't it just turn back into the mud from whence it came. So to satisfy my own curiosity I started googling.
Sadly, according to Google, to understand the "why" it seems you need a degree in chemistry, which I do not have. Basically there are chemical reactions in the setting type that cannot be undone by adding water, and there are additives in the drying type that gas off, chiefly ethylene vinyl acetate. Without replacing them you'll never get the same consistency. I suppose if you added those chemicals back in with the water you could get there but as Bobfandango pointed out, mud is so cheap why would you go to such lengths. I'm not sure what we learned here today but the short answer is: no.
My understanding from a basic chemical point of view is: no, even if it looks similar it will be a different product without the strength or bonding qualities of the original.
Rehydrating set PVA mentioned in previous comments is problematic +1. Also the product contains limestone in the form of hydrated calcium (calcium hydroxide). When it is kept wet it stays in that form but in contact with oxygen it reacts and turns into calcium carbonate (also called limestone but chemically different). When drying into calcium carbonate it creates cure into the hard shape that it is molded into. Where as using calcium carbonate rehydrated solution there is no chemial curing, and the bond is weak, powdery and easily cracks, chips and crumbles.
It's the difference between a limestone block and a limestone powder mud pie.
To turn limestone (calcium carbonate) back into limestone (calcium hydroxide) you first need to add 825C of heat to turn into limestone (calcium oxide), and then add water through a process called slacking, which turns it back into limestone (calcium hydroxide).
I am a taper and you can rehydrate any of it and if it has chunks; you need to slowly add water to make sure the needed abrasion happens while getting mixed(if it becomes souppy; won't be quick). If it is 90,45 or 20; then very hot water after if possible having heated the the mud in the container and let sit covered in a hot area and the water will dissolve it and when you can mix it; add wood glue and use it as a taping mud.
Hello, and welcome to Home Improvement. Thanks for the answer; keep 'em coming! – Daniel Griscom Jun 8 '19 at 12:31
I was successfully able to rehydrate enough to patch a few small nicks from removing wallpaper and holes from pulling out nails. So keep that dried-out tub in a sealed plastic bag in case more small projects like this pop up.
This make it useful as a spackle or hole filler, but not for actually taping drywall joints. – isherwood Feb 8 '18 at 15:34
I have rehydrated mud by adding water and mixing I am talking about premixed mud , hot mud can not be rehydrated, I used to buy mud in a dry powder form and ran out with only a small amount needed 30+ miles out of town I put in some water and used a drill powered mixer to rehydrate some old premixed added more water until it was the right consistency and it worked great, I do save the plastic sheet on buckets now and it never drys out or at least within a year or so. I use both paper tape and the nylon mesh depending on the area and have not had a problem rehydrating some but it takes a little time to get it mixed.
To the originator, Bob... #1. to answer your question ... DIRECTLY, YES you CAN revive it by adding bits of hot water at a time, slowly and with a mixer, but make sure you first break it down into a powder form instead of chunks. I did this with a glove and my hands. Just crushed it. It's easy. Then mix it to your consistency. #2. Ignore people who say it's cheap, just go out and buy some. We're all DIY'ers and just want answers to our questions. #3. I personally did this because I have lovely irresponsible family members that don't put lids back on containers. I spent the money to buy it, I didn't want to have to go out to buy any more. So from some research, I broke it down, boiled some water, got my mixing beaters and attached it to my drill, added some water, mixed, repeated until I liked the consistency. I was also using tape to cover so I put some UNDER the tape to more or less, glue it, then adhere'd it on top as well. It worked perfect and looks great. Good luck. BTW, YES, I know this was 6 years ago, but this will help the next person, LIKE ME, that ALSO googles this same question. People stop hating and just give an answer. Stay Healthy & Safe
Ok so im a girl and I know yall think we dont know but I actually bought two 5 gallon buckets of compound from a junker thinking it was paint. It was very convincing. Very thin and white. So when I get it home and figure out what it is I leave the top off and say fludge it. By the time winter rolls around and I discover I might actually be able to use the crap its not quite dry but on its way. I added water and stirred and stirred and cussed and stirred. Let it dry the rest of the way up. And decided to try a blender. And it worked it wasnt perfect but there were no lumps and I added a little bit to much water so it had to dry a little, but I finally got it to a consistancy where it could be spread with a nice smooth finish with no little gritties. I didn't use beaters however, I used an attachment used for soups it is round at the bottom with a piece of metal in the middle. Good luck!! A puree is what the thingy is called. Just remembered!!
