I am planning to waterproof a basement. (please see the attached picture). I would like to know if the component labeled collector on my attached picture is needed. Since my lot is virtually flat I am wondering if I have to slope the yellow pipe and how much would I need to do it since that dictates how much deeper I have to dig
This is a finished basement and I don't think that I am getting a lot of water. I can smell something wet but it is on and off and only in specific areas. The wall has a crack under the right side basement window. I just wonder if I need to seal the crack and if I can just waterproof that area under the window and no French Drain at all or I do have to go for the entire wall.
The corner that is next to this window has some exterior efflorescence above the grade which I am told it is a sign of underground wall humidity. There is also a patio that seems to be level instead of being graded. This may be the cause for that increased humidity and for the water that collects in the left corned of the patio near the basement window that has the crack.
I was thinking that a surface French Drain might eliminate to problem but I suspect that the patio is in fact permeable to water and the clay soil might in fact be the one that drives the water to that corner
What would you recommend in this case? It has to be a DIY solution, we just bought the house and we can't afford to spend lots of money (tens of K) to fix this
For more pictures please see my other questions related to this topic posted in this forum
