Well, the kitchen sink was leaking and a family member stuck a bucket under there and never told anybody. The problem is the pipes under the sink actually go into the bucket and it is full of water that smells HORRIBLE. I can't move the bucket without spilling horrible smelling water everywhere. I tried using a fast food cup to remove small amounts at a time but the fumes made me light headed and I got some on my hand.
Any other ideas at all? My brain isn't working correctly after breathing that stuff in.
  • I think I'd try pouring in a disinfectant -- laundry bleach, for example -- and hope that broke down enough of the gunk to make dipping it out tolerable. Otherwise, the only solutions I can think of involve cutting the pipes and repairing them later. – keshlam Sep 28 '14 at 3:57
  • I threw some powdered ajax on top a few minutes ago. Hopefully the smell can be neutralized at least a little bit. – 5656meow Sep 28 '14 at 4:00
    I'm not sure what's in Ajax, so I don't know whether you still have the option of bleach or if you'd risk creating poisonous gasses. I think you'd be OK, but I'm not sure I'd want to bet my lungs on it; might be wise to contact the manufacturers before trying that. – keshlam Sep 28 '14 at 4:03
  • It has bleach and a few other common ingredients used in scouring powders. I'll come back to it in the morning and maybe try the cup method again. – 5656meow Sep 28 '14 at 4:06
    Make your relative that left it under there without telling anyone empty it? – user23534 Sep 28 '14 at 4:37
You should siphon the water out using a tube or flexible pipe. I have included an article containing instructions on how to do this here. You will have to adapt it to a much smaller scale, but the principle is the same. If you just do a search for siphoning, maybe you will find a better/more applicable example. I just chose this article bc it wasn't about stealing gasoline. Let's not promote that slimy practice, shall we?
I had to do this once when the grease trap got clogged at work backed up into the sink. It was 11 pm and I had to get the "water" out of the sink so it wouldn't sit there all night and stink up the whole place. There was no WAY I was sticking my hand in there to scoop it out. Siphoning works. Give it a try.
  • Certainly should work if you have or get a suitable piece of tubing. Good thought. – keshlam Sep 28 '14 at 17:19
