I want to replace my non-programmable RobertShaw 9500 thermostat with a programmable thermostat.
The current wiring uses these terminals: RH, W, Y, G.
With that set of wires, can I get a wire-powered thermostat with battery backup, or does it has to be battery only?
You will not be able to get a "wire powered" thermostat, without at least one more wire. You'll need an additional wire, to connect to the C terminal of the new thermostat.
