We're in the process of replacing some deck boards, and are wondering if we should replace a section of the cement block wall. We're also not sure what the best way to go about it is. It's apparent from feeling where the block has deteriorated at the bottom, that it was not attached to the concrete floor. Replacing the block is one option. If we go that route, should we attach the blocks to the floor some how so that the same thing does not happen again?
What I was thinking I wanted to do, was remove the wall W1 in the picture and replace it with a wood post P1 that gets cemented into the floor. Is this a good idea? I don't think the wall is serving any function and all it's doing is keeping water trapped behind it, though I may be wrong?
We're In Minnesota so the snow and freezing temperatures are something to consider.
