I had a new downflow 80% efficient furnace installed in 2006. I don't use it regularly as I normally heat my home with my woodstove (separate chimney). But I have used this new furnace many times during "in between" weather, and when I have been out of town. It has always worked fine. Then in 2011, I used the furnace regularly for a few months that winter. I noticed that I had water or condensation running down the pipe that goes from my ceiling to the furnace - it would happen after the furnace ran for a bit. It got to the point that I had to put a pan on top of the furnace to catch the dripping "water". My immediate thought was that my chimney stack must be cracked as I know the hot air from the furnace meeting the cold air in the stack (if it were cracked) would cause condensation. But after taking off the chimney cap and checking - the stack is fine. My chimney cap was blown off during a windstorm, and now is slightly damaged and sits a bit lower than previously. Could this be causing this problem? I was told by one furnace guy that my chimney stack is too large, and that it needs to be lined to make the opening smaller, and to replace the chimney cap. He swears this will take care of the problem. I'm just wondering why it took 5 years before I had a problem. Could it be because I was not running it 24/7 like I started to in 2011? I hate to pay for all this work if that isn't the solution?
  • Is that down the inside or outside of the pipe?
    – DJohnM
    Sep 25, 2014 at 19:47
Sounds legit. As you decrease the temperature of air inside the chimney you decrease the flow rate out of it causing the mixing with cooler air to happen in the chimeny rather than out of it. It could be that this didn't happen in 2011 because of warmer outside air temperature, different humidity conditions, or that your exhaust was running hotter/faster then. If you use the formula on wikipedia you can calculate your desired chimney cross section (just remember to use metric to stay consistent). Also the damaged cap definitely could slow your flowrate which could contribute to this issue.
