So I've been doing a lot of research recently regarding LED lighting, and attempting to do an overhaul of our entire house. But I've run into a few issues, and I really don't want to go back and forth testing out different LED bulbs to see what's going to work, and what's not going to work.
All of the Q & A i've found on this site is either OLD or not really related to my issues. So bare with me...
We have 2 Poll Lamps that are a 3-way switch of 50w/100w/150w. I know there are LEDs now that exist as 3-way bulbs, BUT i've only seen 30/60/100. Question: Is this type of bulb ok with my lamp? If not, what type of LED bulb would a person use? Do I have to find a 50/100/150 watt LED, if so, do they even exist?
People have been saying that using a Dimmer in this situation would work. Question: What kind of Dimmer would work for my the 50/100/150 watt scenario?
We have a TON of R40 Reflector type fixtures in the house, and most are setup as dimmer, and a few are not. I've only recently started taking care of the appliances and utilities of the house, and don't really know what wattage the lighting fixtures take. I checked one of the R40 Dimmer halogen bulbs, and it was set at 120v 65w. I checked a different one and it said 130v 65w. So i'm assuming i need 65w bulbs. Question: How do you check for the wattage on this type of lighting fixture? and whats the deal with the 2 different voltages?
We have a ton fluorescent lighting in the house, and it's old and was installed at least 30 years ago. I'm under the assumption that these take tons of power to operating, but I've never checked any statistics on this. I was thinking of removing the fixtures entirely and replacing them with something that's LED equivalent, Question: Does anyone have any suggestions that would replace this type of lighting?
It should be noted that money is not really an issue but I don't have a money tree in the garden.
