I am living in house in which the sun is not overlooking through the window at all, Is there a way to make overlook at least partially inside the house.
2I'm not sure if your question really has a practical answer. Put in new windows or a skylight? Do you have a solid door that you could replace with one containing a window? Put a bunch of angled mirrors in your yard aimed at your windows?– DoresoomSep 19, 2014 at 19:56
are there trees outside that you can trim to let light in?– ljkSep 19, 2014 at 20:04
1Does sunlight hit your roof and are you an the top floor?– bibSep 19, 2014 at 20:26
@Doresoom Mirrors? Some inspriation.– gregmacSep 19, 2014 at 20:41
2@gregmac: As long as it's not parabolic!– DoresoomSep 20, 2014 at 4:21
1 Answer
Tubular skylights, a suntube in use and available from Solatube. There's roofing and carpentry involved but no framing needed. They're the only way to have a skylight with an attic above without blowing out your ceiling. Cut 2 holes, flash it to the roof, enjoy.
I have the opposite opinion. My aunt has these and they are useless IMHO.– Evil ElfOct 17, 2014 at 13:11
