Background
Most current and past hand-plane makers seem to follow the numbering system (and design details) popularized by Stanley (and invented by Leonard Bailey?).
There are a bewildering number of different types of plane, but there seems to be a grouping of the general-purpose bench planes used in converting a roughly-hewn chunk of wood into a straight, flat, smooth, square piece of timber:
  • fore planes - used first to remove large irregularities.
  • jointer planes - used to flatten longer sections of wood.
  • smoothing planes - used last to produce a smooth finish.
A No 5 jack plane is often described as a type of fore plane (in some descriptions it is used after a scrub plane). A No 4 is a typical smoothing plane. One or other of these types seem to be most commonly the ones first purchased and used by DIYers.
Question
I have recently bought a second-hand Record No.5 jack plane and was pondering whether I should buy a No.4 smoothing plane. However it seems to me that the similarities are many and the differences few and that I could probably set up the No.5 to do a reasonable job of smoothing.
Similarities
  • Same iron angle (45°)
  • Same angle of grind on iron (25°)
  • Same width of iron (2 in.)
  • Same size mouth?
  • Same system (identical parts?) of adjustable frog, chip-breaker, lever-cap, etc.
Differences
  • Longer (14 in. instead of 9)
  • Heavier (due to extra length)
Record No 4 plane enter image description here
Images from old Record company catalogues
Is there any other physical difference that makes a No.4 more useful for smoothing, other than it's smaller size and weight making it easier to handle?
Addendum
Following keshlam's answer I found this guide to grinding plane irons which others might find useful
  • Some photos would be wonderfully educational!
    – wallyk
    Commented Sep 18, 2014 at 16:20
  • @wallyk: how about some catalogue engravings? Commented Sep 19, 2014 at 8:57
  • And a scrub plane may have an even more radiused blade. Or may not.
    – keshlam
    Commented Mar 25 at 0:44
The plane iron may also be ground slight differently in shape (as opposed to angle)... but yes, those are the largest differences. They do affect how the plane is used.
A longer plane improves its ability to accurately flatten a surface (it can level out wider-spaced hills and valleys where a shorter plane would just follow the curves). But depending on what you're doing, the additional weight may be tiring or may be helpful -- harder to lift, but the weight helps keep the iron in contact with the wood.
The ideal hand-tool woodshop has a range of planes from jointers (long) all the way down to block planes small enough to hold in a hand, plus various specialty planes (shoulder planes, rabbeting planes, router planes...) each of them having its own trade-offs -- just as the ideal woodshop has a range of chisel sizes and types. Most of us don't have ideal shops, and that's OK. You can do the same jobs with a smaller setup, it may just take more work and care.
If I had to pick just one of those two, I think I'd have gone for the #4 first... but that may be personal bias; I've already rescued several of that size from various garage sales, and because I haven't had to do serious smoothing/jointing yet. And I'd suggest a block plane as your second purchase -- they're light enough to carry anywhere and more useful for spot-trimming than you might think.
If you do buy a 9" plane, it's seriously worth considering a low-angle plane (lower bedding angle, higher angle on the blade). Among other things, that gives you a wider range available if you need to grind blades to other angles when handling special cases. These do tend to be a bit more expensive, though, largely because this design is mostly offered by the higher-end manufacturers.
(Edit: Yes, I know, "long jointers are long, duh". Redundancy fixed.)
