This question already has an answer here:
Here is our setup
  • Outlet in older house that was replaced with a GFI last year. (no issues until recent)
  • The GFI doesn't have a ground wire running up from the basement. Just the white and black wires. (From my understanding this is an acceptable configuration)
  • The outlet reads 119.0v when checked with my multi-meter.
  • The outlet reads less than a volt when the "positive" line and the ground are checked with the multimeter. Same with the "negative" with the ground.
  • A (real) surge protector plugged into the outlet
  • A large tv plugged into the surge protector
  • A cox cable box plugged into the surge protector
  • A coax cable (run by cox) from the outside of the house, split and sent to a modem and the cable box. The coax reads 0v (no leakage at all) when a multimeter is placed on the inner coax wire and the outer shielding. I tried this on both DC and AC settings on multimetter
The problem:
When either a coax cable or HDMI cable is run from the cable box to the TV, an Arc appears. This has already fried one TV.
My theory:
The coax cable is improperly grounded. I just need a way to prove it. The basis for this theory is the coax cable in a separate apartment tests with an AC voltage of 1.5v. The cable technicians are somehow less informed about circuitry than me. This is a hobby for me so I am lost in the sauce. Any Ideas?
Update
So I took the time to diagram what I have observed. This further supports my theory that the cable isn't grounded properly. I'm not 100% sure how coax is supposed to be run from a telephone pole though so I could be incorrect.
Just in case there is confusion, no the neutral is not plugged into the ground. I was just demonstrating that there is only two wires going to the GFI.
(Please right click and select open in new tab to see full size image.)
marked as duplicate by Niall C. Sep 15 '14 at 4:03
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
migrated from electronics.stackexchange.com Sep 14 '14 at 21:48
This question came from our site for electronics and electrical engineering professionals, students, and enthusiasts.
  • What is the voltage between the coax shield and ground? – Ignacio Vazquez-Abrams Sep 14 '14 at 20:17
  • @IgnacioVazquez-Abrams if you are talking about the one at the cox exterior box, I didn't test it. I didn't want to mess with their stuff in case it was screwed up so they couldn't blame it on me. – Anthony Russell Sep 14 '14 at 20:25
