I live in the UK and I just had a tree surgeon round to cut down a tree. He cut the trunk up into 6" pieces and my grandad plans on using one of the cuts to make a table. However, the trunk, which is about 60cm in diameter, is too thick and heavy at the moment and I need it cut down into 1-2" thick pieces. Because of the size we don't have any tools which will get through it neat enough. Does anyone know of a company/tool which can provide this service/effect? Shame to see all this good wood go to waste.
I don't know about the UK, but in the US I'd look in the phonebook or online for "portable lumbermill service". There are indeed devices which can be brought to a jobsite and set up to slice boards from a felled trunk. Definitely worth considering for hardwoods, if you have a place to store the resulting lumber until it dries (typically a year per inch of thickness for air-drying). Cost per board-foot is usually quite reasonable.
The tools can also be purchased, of course. Some are as simple as a guided chainsaw with a longer than usual cut and a chain ground specifically for ripping. Others are guided bandsaws. The guides can be as simple as rollers following the surface of the previous cut (using a 1x12 nailed to the log to guide the first cut), or can be full frames with built-in tracks for the saw and mechanisms to assist with rotating the log to obtain the best grain patterns.
Or, if the wood's at all interesting, you could see if any local sawmill would be interested in buying the logs, and ask them if they could cut the slabs you want as part of that deal.
You need a large band saw and a cradle to hold the tree. Alternatively, a chainsaw will work, but it won't be as neat.
