Short version (TL;DR): how can I measure the output pressure of a water pump in a spa heating system and verify that it is within the gas heater input pressure specs?
The Whole Story
I'm trying to troubleshoot an outdoor spa heating system in my parent's home which is located in SW Brazil. Its simplified diagram is as follows:
(just replace the word pool by outdoor spa and remove the word filter and that's exactly what I have)
The heater is about 6m (20 feet) away (horizontally) and 1.5m (5 feet) above the pump.
The Pump
The pump picture and specs are the following:
- Power: 220W
- Input voltage: 220V AC
- Frequency: 60Hz
- Maximum temperature: 90ºC
- Maximum pressure (suction/input): 60mWc (meters of water column) or 85psi
- Maximum pressure (output): 12.5mWc or 17.8psi
- Maximum flow: 58L/min
- Connections: 1''
- Weight: 5.0kg
- Country of origin: Brazil
Product link: Texius TBHGF • 220W
The Gas Heater
The relevant gas heater specs and info are below:
- Minimum water input pressure: 2.5mWc or 3.5psi
Product link (similar to mine, which is outdated): Orbis passage gas heater - model 315
Symptoms
The heating system was working properly until we noticed a significant decrease in the hot water flow coming into the spa and increase in its temperature. After a while, the heater would turn off even with the pump turned on. Now the heater won't even start (it won't even make the sparks that light up the gas). I did replace the 1.5V D alkaline battery, but no joy.
Questions
Assuming the problem is the reduced pump output pressure, how can I measure it to make sure it's really under the minimum heater input pressure?
I am looking for solutions involving any of the following:
- a DIY apparatus to measure the pump output pressure
- clever ways to make measurements and physics equations to calculate the pressure
- off-the-shelf measurement tools and gadgets (the cheaper the better, for occasional one-off measurements like in my case)
Are there any other possible causes for this problem?
Research
Well, I did try to ask Google this same question, but could not make any sense of the results. Maybe I'm not asking the question properly, or I'm not using the right keywords.
PS. I have converted the pressure units to PSI using ConvertTop.com - pressure.
