I bought some industrial strength low profile velcro in order to make wall mounting stations for a fan. The fan (about 8 lbs) slides onto hooks screwed into 24"x7" pieces of 1/2 inch thick MDF. The loop side of the velcro is stuck to the back of the MDF in two ~23 inch strips at the top and bottom, and the hook side is stuck to the wall.
I put these up in two places and let the adhesive sit for 24 hours before using them. On one, the MDF-adhesive bond started failing after about 12 hours of holding the fan, and on the other, the MDF-adhesive bond started failing after about of week of holding the fan intermittently.
How can I prevent the adhesive from peeling off the MDF? Would super glue stick better?
Super glue might work, although my first thought was to finish the mdf with polyurethane first. This will seal the mdf and allow the adhesive to remain sticky for a long time. Rubbing superglue on the area before the velcro goes on might get the same result too if you don't want to finish the whole thing.
I think this is what's going on : the mdf is very porous and absorbent. For example, it soaks up finish rapidly until it's saturated and only then can you build up finish thickness. I think the mdf is basically extracting the lower molecular weight components out of the velcro adhesive, which are the that make it tacky. With those gone, the adhesive is now more brittle and fails in short order.
  • Would polyacrylic also work? (I already have some of that) Sep 4, 2014 at 16:00
  • I don't have direct experience with it, but a quick google search tells me that it should be very similar to how regular PU would work in this situation - at least as far as the adhesive is concerned. HOWEVER, because polyacrylic is water-based, it may swell the MDF more than you want (since the MDF will really drink it up). You may want to test this on a scrap piece first before doing it on the real deal.
    – aaron
    Sep 4, 2014 at 17:42
  • I've also had great success with a few staples through my velcro into the substrate. They're usually not enough to affect the holding power of the hook and loop, and do a great job keeping the velcro in place, especially if it's to be moved. However, additional note from personal experience, velco does not play well with vibration and movement. Jul 1, 2015 at 17:17
