Just moved into this house a few months ago, and noticed the stub wall in the shower that holds the controls has cracked grout.
I'm guessing that somehow water got in behind the tiles and started to swell the supporting studs, which blew out all of the grout in the area.
What should I do to fix this?
You can see the tile is separating perpendicular to its surface.
Here too.
