The Maytag Bravos Quiet Series 300 washing machine has a display. It displays codes sometimes. Is there a list of status codes?
Here are some: laundry.manualsonline.com/manuals/mfg/maytag/…– DA01Sep 2, 2014 at 18:40
Have you checked the Maytag website, or contacted technical support?– Tester101Sep 2, 2014 at 18:41
1 Answer
From the Maytag Bravos® Use & Care Guide (PDF)
Code Reason
LF Washer is taking too long to fill
Ld Washer is taking too long to drain
uL Unbalanced load
oL Overload
Sd Suds detected
lid Lid open
HC Hot and cold supplies reversed
dL Door/lid cannot lock
dU Door/lid cannot unlock
Fd Factory Default
F_ _ Fault code
If the machine is showing one of the fault codes, you'll have to contact Maytag. The list of fault codes is probably not publicly published, and is likely only available to Maytag service people.
